09-07-2022 07:22 PM
My friend recently gave me his Oculus Quest 2 since he got a new vr headset and told me to factory reset it since I was having some issues with it not loading anything. (Not being able to look at the store, not being able to add my account, etc.) After I reset it I was not aware that he did not do the software update, so now whenever I try to pair the headset with my Meta Quest app it tells me to update it even though I am stuck on the controller pairing screen. So now I’m stuck in a loop of being stuck at the set up screen and being told to update the headset. I’ve already tried a sideload update and removing the batteries of the controllers and putting them back in, but to no avail. Please give me some tips/advice to fix this.
09-07-2022 11:16 PM
I had this trouble after googling I found a site showing you to put headset into side load mode and connect to pc down load the 43 update on the website I found and another software and it now paired
09-08-2022 01:17 AM
Same here, Meta is seriously messed up!
03-07-2023 12:45 PM
Did you have to buy the Oculus Link cable?
