My oculus won’t turn on with factory reset
CITYGURL82
I have a oculus quest 2 I haven’t used it in over a month I tried playing it today and it won’t turn on with factory reset no nothing I charged it for a whole day and while on charge the screen keep going off and on with the oculus symbol flashing. Is anybody else having this problem and was able to fix it?
Fatty19
That happened to me a few times after updating to new versions. I have no idea how or why, but if I recall if I plugged it into my PC with a Link cable and then tried to start it again, it worked and would then function normally. Worth a shot.
