Oculus Air Link won't connect to my computer
When I try to connect my Oculus Quest 2 to my computer, The computer does not detect my Oculus Headset. Please help
6 REPLIES 6
Hey there Bucky-Quack-Mucky,
Don't worry! You called for help and we're here!
When your computer wont recognize the Oculus Link please try:
  • Reinstalling the Link driver on your computer.
You can find the installable Oculus driver file at the following path: c:\Program Files\Oculus\Support\oculus-drivers\oculus-driver.exe.
I will include a Oculus Support article for you to refer to for additional information for Troubleshooting Oculus Link.
After attempting the troubleshooting steps and you continue to run into the same issue please submit an Oculus Support ticket so that we can look further into this issue for you.
Have a great week!
Thank you for replying.
But your advice did not work, i even went out and bought an Oculus Link chord and it still did not connect.
Thank you in advance.
Hey Bucky-Quack-Mucky,
We appreciate you working with us on this, we still want you to be able to game. We're not giving up!
Please attempt these additional troubleshooting steps, hopefully this will resolve your issue.
  • Disable airlink on the headset and the airlink toggle will be replaced for the wired one.
  • Make sure both your Oculus PC software and Oculus device is updated
    If you still can't enable Oculus Link after updating your software, you can try these troubleshooting tips:
    • If you don't see Add Quest as the device on the PC software, log out of the PC software and log back in.
    • If you don't see the Enable Link pop-up on the PC software, log out of the PC software and log back in.
    • If you don't see the Enable Link option under Settings on Quest, completely power off the headset and restart it.
We’re aware of an issue where Oculus Link fails to connect compatible laptop models to Quest. Until a more permanent fix is ready, restarting your PC can often fix the issue temporarily.
Lastly, once you attempted the troubleshooting steps and you continue to need assistance, please submit an Oculus Support ticket we'll be able to do more research on your issue.
Enjoy the rest of your day!
shadriane99
nevermind lol
Try this, connect your Quest 2 using USB to your PC but don't turn off your Oculus Air Link on your Quest 2 and open Oculus Apps on your PC then try connect new device via USB.
