Oculus Developer Hub
Teampuxty
Hello!
I am trying to upload a game to my Oculus Developer account but get the following error:
ERROR: We found issues with the APK during validation. Please check that the APK meets the 'Application Manifest Requirements', then resubmit your app.
* The APK installation location should be "auto" ("android:installLocation" in AndroidManifest.xml). See documentation at: https://developer.oculus.com/distribute/publish-mobile-manifest/.
My manifest was this:
<?xml version="1.0" encoding="utf-8"?>
<manifest
<manifest xmlns:android="http://schemas.android.com/apk/res/android" package="
com.SwampyGames.BasketballTrainingVR"
android:versionCode="1"
android:versionName="1.0"
android:installLocation= "auto">
<application>
<meta-data android:name="com.oculus.intent.category.VR" android:value="vr_only"/>
<meta-data android:name="com.oculus.supportedDevices" android:value="quest|quest2"/>
<activity android:screenOrientation="landscape"
android:theme="@android:style/Theme.Black.NoTitleBar.Fullscreen"
android:configChanges="density|keyboard|keyboardHidden|navigation|orientation|screenLayout|screenSize|uiMode"
android:launchMode="singleTask"
android:resizeableActivity="false"
android:name="android.hardware.vr.headtracking" android:required="true" android:version="1" />
</activity>
</application>
<uses-sdk android:minSdkVersion="23"/>
<uses-feature android:glEsVersion="0x00030001" />
</manifest>
I am using Unity but have no idea why this isn't working. Please can you help if you know!
aspen1024
Hello, did you solve this, im having the same problem, dont know why building for oculus is such a pain in the ass
