Oculus Quest 2 being bricked solution.
JoyfX
You may have connected your oculus quest 2 to your PC or charged it and for some reason it’s stuck in USB mode. I have a solution! This may not work but what I did was scroll to the bottom and hold the volume and power button for nearly 45 seconds. Then when you see a dead android guy with his chest open saying “No command” and the LED light is purple leave it be. Sooner or later it would make the startup noise. If that doesn’t work let it die and charge it until it’s green. Hope this helps.
0 REPLIES 0
