Oculus Software Issues
shawn_warriner
Hi, I recently bought a Quest 2 and the Quest Link Cable. Unfortunately, I cannot install the Oculus Software. The install seems to get 10% done and then I get the "encountered and error, please restart" message. I've read numerous threads in this forum and tried every work around I could find in those threads, but I'm getting nowhere.  Attached is my Setup Log. I'm not computer savvy at this kind of detail, so hoping someone can help explain what is happening and offer a solution if possible.
Thanks.
TwrchTrwydd
Level 6
Since the log reports "System.Security.AccessControl........." problems you should try to run OculusSetup.exe as administrator.
