Oculus link issue
DogeWith_Vr
Everytime I open oculus link, I can't see the desktop button on the menu, and this thing called "XRS Debug Window" pops up. Everytime I try to close the window, oculus link stops. I have tried restarting my headset, and even doing the setup again, and nothing works. Please help.
23 REPLIES 23
DRAKG0
Im experiencing the same after the last update, im going crazy since performance is droping around 70% on Quest2+3090 and cannot find any way to close the "XRS Debug Window" without stopping the PC-link.
softest_poly
This is happening to me too after the last update
Sal_16
Same!  Following for any updates and/or recommendations...
Is it possible to go back to the last version?
Seems a problem related to latest v46 beta version, going back to normal v44 seems to solve it till they post a proper solution. Deactivate beta under settings-beta-ptc and reinstall under library-updates.
This worked!  Thank you so much for your reply; this saved me hours and many curse words 👏
nabelo
Same here
huliqan
Level 6
rollback to 44 but xrs debug window still hangs on every launch :(((
Marveldude345
The Oculus software updated from the official current 44 to the Oculus software version 46.0. I am having an issue where the xrs debug window it pulls up when I go into link thru the cable. But when I go to close it it also closes and returns back to the quest 2 home screen. Cannot get rid of it nor I can play pc vr games. I heard someone said they know how to force it off but I do not know how to do that and I don't even have the Public Test Channel on in the settings and I have never turned it on before.  I have check everywhere Hopefully someone finds a solution to this.
same too!!!(((((((((((((( How to disable this window ???
