I've had the Rift for about a month or two now and it has worked great since then. However, a few days ago I had to unplug every cable from my computer for maintenance inside the case (I haven't changed anything in the end other than cleaning it), and when I plugged everything back in, it has come to my attention that the Rift wouldn't work, it only shows an orange led instead of the blue one.
The display mode is set to extended, and both monitors are configured as before. The camera works, and in the config utility I can see that the driver is detecting my rift. In the demo's (that show up on my regular monitor) I can see that the head tracking works too.
I have also tried to use the DVI to HDMI converter for the rift, but to no avail.
Any idea what I might have done wrong? Will a system restore perhaps resolve the issue?
Edit: He seems to have the same problem as me, (should have done some research before starting a new topic, sorry) : viewtopic.php?f=34&t=16560
