08-13-2022 05:19 PM
I plugged my link cable into my pc and oculus but before I read anything I accidentally clicked the bottom prompt for it to allow access and now it doesn't even have an option to extract files from either or into eachother. And now anytime I try to link it, it doesn't give me that prompt
08-13-2022 05:24 PM - edited 08-13-2022 05:25 PM
@AutisticDucki wrote:I plugged my link cable into my pc and oculus but before I read anything I accidentally clicked the bottom prompt for it to allow access and now it doesn't even have an option to extract files from either or into eachother. And now anytime I try to link it, it doesn't give me that prompt
Do a little google research on this well documented and repeated question (only surpassed by lost patterns and passwords) and/or contact oculus support I guess, lol!
08-13-2022 07:13 PM
ok so i figured out that i actually clicked Deny and dont ask again so how do i make it ask again
08-13-2022 07:36 PM
@AutisticDucki If you tried Fac resetting the headset. You can go ahead and try a clean install of the Oculus Home software:
Let me know if that does anything for ya!
08-13-2022 07:49 PM
@AutisticDucki wrote:ok so i figured out that i actually clicked Deny and dont ask again so how do i make it ask again
Congratulations, at least you figured that out mate. Now you can try getting a Developer account and enable this with your smartphone and then quick settings/system/developer and enable/disable this feature. Otherwise a factory reset will also fix this.
