Pokerstars VR not loading
wichman06
hello, it is impossible for me to connect to the application, is this normal?
Thank you
5 REPLIES 5
Hi @wichman06! That's certainly something we'd like more info about so we can help get you playing poker with friends.
  • Does the app launch for you and you're just not able to connect to the internet on it, or is the app not launching?
  • Are any of your other apps doing this?
  • Are you able to connect your Quest 2 to Wi-Fi?
We hope to hear back from you so we can determine next steps. Thanks!
wichman06
Thank you for answering me, then, the application launches and remains blocked on the start menu, it is the only application that does this, and I am well connected to the internet thanks to WiFi.... I don’t understand
Thanks for writing back! We're glad no other app is affected. We suggest uninstalling PokerStars VR and then reinstalling it. Please let us know if that gets the app working.
ok, I try....
Hey there! Did uninstalling the app work? If you need more help, please let us know. Thanks!
