05-24-2022 11:24 AM
My eye doctor gave me two prescriptions - one for normal distance (driving etc.) and one for "computer" usage (weaker prescription).
Anybody know which would be the prescription to use for lenses on the Quest 2?
I found some 3D printer files for holders that can be used with the Quest and Quest 2 with round lenses from Zenni. Having someone print the holders and lenses for my prescription would be a third or less of what other companies are asking.
Thanks.
05-24-2022 11:32 AM
The Quest lenses focus to around 2 to 3 metres. So what ever prescription gives you the sharpest vision at that distance is the one to go for. If you already have spectacles with those prescriptions you could carefully try them out in the headset to double check.. 🙂
