Quest 2 keeps disconnecting
sarzul.2022
Rig:
Geforce RTX 3060 Laptop GPU
12th Gen Intel(r) Core(TM) i7-12700H
15.71gb Ram
Kiwi USB 3.0 Cable
Windows 11
whenever i would use link using cable with my laptop it would always disconnect a lot, or while using it for a good while my headset or game would bug out and tweak out.
I read that NVIDIA 3050 (laptop) are not recommended for use with Link but i wonder if that goes the same for my 3060. hopefully there would a fix or update would make it playable if that's the case my laptop being the problem
4 REPLIES 4
Updated this morning, had nothing but trouble, disconnecting every 15 mins. Last update was a nightmare too. Ordered a hp reverb this afternoon and can't wait to swap it over next week, had enough of updates ruining everything I spent hrs setting up.. bye meta lol
im prob just gonna return this and just ball out on a steam vr headset
Hey there! We know important being able to play all your favorites on PC is and we definitely want to help look further into this for you.
Please reach out to our support team so we can get to the bottom of this for you. (https://metaque.st/Support)
will there be support for 3050/3060 laptop gpu any time soon?
