Quest 2 won't connect to PC.
Longfingers
Hi all,
When I connected my Quest 2 to my PC, instead of clicking "Allow to connect to PC" I clicked on "Don't show this message again." Now I can't connect to PC and although I can find it in Devices, when I click on that, it says      "Driver unavailable"
I work offshore and it may be because the internet sometimes blocks from downloading apps etc. but I've never had any problems before when just "Allowed to connect"
Any help would be appreciated. TIA
You probably need to re-enable the USB prompt in the Developer menu on the headset, although that's more normally needed for file transfer mode rather then USB debugging. It's under the System settings page. You may need to enable developer mode on the phone app first.
