Reestablishing Parental Supervision
mmc0402
Honored Guest
Hi - parental supervision was working well until my son turned it off. While trying to reestablish, I’ve receive the invite link via text, but when the app opens, there is no option to actually complete the request. Also, the Parental Supervision section is no longer on the screen at all. I’m running v188.0 in iOS.
1 ACCEPTED SOLUTION
Accepted Solutions
Onejk
Honored Guest
I managed to get this working by using the link generated by my son on a device that didn’t have the meta quest app installed.
3 REPLIES 3
Onejk
Honored Guest
I have exactly the same issue. My son sends me the link and all that happens is the app opens up. No option to accept anything and no parental supervision options in the menu!
Onejk
Honored Guest
Thanks so much for responding!  It worked!
