08-29-2022 08:40 PM
I have tried everything support recommends but I can not get my
oculus to pair to the app. It’s a replacement/refurbished one … the only thing I see on the oculus is the 5 digit pairing code. I enter it and I get the “unable to connect”. Bluetooth is on … bluetooth even recognizes the head set as an “Oculus Standalone HMD” and IS connected. Anyone have suggestions? (Already reinstalled apps, factory reset, etc). HELP!
09-02-2022 02:02 PM
Everyone is having the same issue after getting replacement headsets. So far, haven't seen anyone find a magical solution to the issue.
All I can recommend is you open a Support Ticket with oculus so they know how bad the situation is and force them to release an update faster.
