Rift S in conflict with integrated graphics : Solution ?
sikozis
Hello everybody, I had issues with my rift S getting two black screens and then not displaying any image in the setup section. I mailed the support with logs and said the following :
"You have two graphic cards, one from your CPU Intel(R) UHD Graphics 630 and your Nvidia Graphics card. This cause the device to not use the Nvidia GPU as it select by default the CPU graphics card. Your computer is not VR ready with an oculus rift S."
They told me I could look up for help here, and try my luck. I use my CPU to run two additional monitors. Is there any workarounds I could try to make it work or am I just a dummy for not knowing about this ?
Many thanks
0 REPLIES 0
