05-22-2022 12:22 AM
The height in the PCVR version of Robo Recall puts me in the floor. See video for details on this problem. Can i get help fixing this issue? Thanks!
05-22-2022 03:27 PM
Hey there! We see you are having issues with your guardians' height, worry no further we're here to help.
Please attempt the following steps in this link, in hopes of finding a possible solution: https://metaque.st/GuardianTroubleshooting
If needed, we advise resetting your guardian in your settings. Once you're done and if the issue persists try rebooting your headset, please. https://metaque.st/QuestRestart
If needed, feel free to send us a PM or submit a support ticket. https://metaque.st/Support
To PM us, please select our name to get to our profile page, or click here: https://metaque.st/CommunitySupport. Next, click "Send a Message" to privately message us! Please remember, that you must be signed into the community first to send us a private message.
05-22-2022 03:38 PM
As I Explain in my video attached to the initial post, it is not an issue with the quest 2 Guardian as this is the only game that is affected and the guardian shows the floor in the correct location even in this game.
05-31-2022 07:54 PM
I have the exact same problem with this game. Typically only happens when trying to play via Virtual Desktop. Did you ever find a solution?
09-21-2022 11:15 PM
I‘m also facing the exact same issue. But only when using virtual desktop. All other games are working perfectly fine with VD. Did anyone find a fix for that?
09-22-2022 10:48 AM
Hello! We see you're experiencing issues with the game ROBO Recall, and we see you mentioned that it's the only one that's not working properly, don't worry, we've got your back. Let's see what we can do to help you out.
We'd like you to contact the developer and see if this is a known issue so we can get you taken care of. More information about the ROBO Recall can be found here or here.
09-22-2022 12:50 PM
Hi, I'm having the exact same issue. Did you manage to solve it?
05-01-2023 07:45 PM
I have the same issue. Did you ever find a fix?
05-02-2023 05:40 AM
Sorry to say I did not. Ended up having to not use PCVR as it works as expected without VD for some reason.
11-27-2023 07:29 AM
To make the height correct when playing Robo Recall using Virtual Desktop, you need to change a setting in Robo Recall: Disable 360 degree tracking, select front facing only in the game settings.
Alternatively you can use AirLink instead of Virtual Desktop for this game.
