06-28-2021 01:38 AM
Greeting everyone! I recently took a better look through my lenses during gameplay and noticed both lenses have weird smudges but I can't clean them. Could they be somehow underneath or inside the lenses, or maybe they got fogy from the inside? I just can't seem to clean the off...They just make ghosting look even more noticeable...
07-01-2021 06:29 AM
Hi, if you haven't already please open a support ticket with us here and please include a picture of the issue. Thanks!
01-17-2022 11:40 AM
I notice the same thing. Did you get a resolution?
01-17-2022 11:41 AM
It’s not something easy to take a photo of because of the lighting in there. May be able to get it on video as it depends on the angle you look.
01-17-2022 01:15 PM
My son was wearing his glasses, but didn't put the additional black plastic insert in first, so I'm thinking his glasses scratched the VR lenses right in the center where there's been physical contact.
02-11-2022 02:52 PM
Mine is brand new and i have same issue. It's like a permanent smudge on the lens. I can't clean it off. It makes certain VR videos unbearable.
02-12-2022 02:40 PM
Hey there! Not being able to enjoy the immersive world of VR could be a real bummer, especially when your brand new device has what appears to be smudges on the lens that you are unable to clean! We want to make this right for you so that you can finally start gaming comfortably. Please feel free to send us a PM, including a picture or video of the issue you are having, and we'll be more than happy to assist you with this. We look forward to hearing from you!
04-30-2022 03:26 PM - edited 04-30-2022 03:28 PM
The same is happening for me the smudges are on both lenses it is the thing that is circled but you can also see it all over the lens
05-01-2022 08:56 AM
If you've been rubbing the lenses to clean them you may have removed the very thin top layer. The lenses are like spectacle lenses and have a thin coating to make them more scratch-resistant. if you have rubbed through this top layer you'll leave behind what looks like a smudge but is actually a hole in the top layer. The only way to help might be using Polywatch or something similar to carefully remove the whole top layer, but the lens will never be perfect again.
06-08-2022 03:11 PM
Take it apart clean it with eye glasses spray and use air compress can to blow the lint. Put it back together.
