Solved: 4 Quest 2 in same room
wen.jiang.56
I checked a lot of information, I think it is possible in theory, I want to confirm whether the following is feasible
1. Would you like to ask if a room of 15Mx6M can use 4 sets of Quest 2?
2. Will using PCVR with WiFi6 to stream the Quest 2 wireless signal may cause the Oculus Touch controller to be delayed or unresponsive?
Is there a definite answer? Or if someone has a similar usage situation, please let me know, thank
0 REPLIES 0
