Using Quest 2 outside
jbistoocool
Can I use my oculus quest 2 outside. I have a nice covered shady area where I have enough room to play my games, but I'm worried that any sunlight eould damage it. There's no direct sunlight however, it is all shade.
1 ACCEPTED SOLUTION
Accepted Solutions
BlueberrieSmoothie
Meta Quest Support
Meta Quest Support
Hey hey! You should definitely NOT use your headset outside. Even though it may not be direct sunlight, it's not worth the risk of the possibility that you could cause any sort of permanent sun damage to the lenses. That type of damage isn't covered under warranty, and you don't want to get stuck with weird looking spots of damage in your headset that you can't fix. Of course, how you use your headset is completely up to you, but you won't have any replacement options or anything if that happens.
3 REPLIES 3
It's not recommended unless you are 100% certain that no sunlight will fall on the internal lenses and you don't sound like yu are 100% certain. Even if you are, it's probably still not recommended.
BlueberrieSmoothie
Meta Quest Support
Meta Quest Support
EL_PANCHO55
Okay, I try lots of times to use quest2 at outside and search the YouTube to find a way but NOOOOOO !!!!
anyone help about this actually servers too. I wrote mr. Zuckerberg 😑 so ; NO ANSWER 😅
