07-29-2022 05:47 AM
Windows 11.
Oculus Quest 2
Oculus link to my Windows PC
Running Virtual Desktop.
While I'm using virtual desktop. everything seems works well.
but when I move my mouse cursor over a any type of text input field, mouse cursor become invisible immediately.
cursor become visible again as I move cursor out of text field.
I had take off my headset and checked my monitor, cursor was visible on my monitor. it was only invisible on my headset.
Please help.
Thank you.
08-02-2022 12:35 PM
Hello there! Thanks for reaching out and sharing your experience with us. We understand how this can be a bit annoying when wanting to enjoy your games.
Thank you for providing your information. We'd be happy to look into this with you starting with a few questions.
Does this happen in one certain app or all apps?
Does it happen when playing Steam apps, Oculus apps, or both?
Does it happen during standalone play?
Looking forward to your response!
08-04-2022 10:33 AM
Hi. We're reaching out to see if you still need assistance. Let us know if you do!
08-05-2022 01:33 AM
Hi.
I don't know what happened. but after a few days. it somehow solved itself.
I'm not sure what was causing this issue. but right now I can see my cursor wherever it is.
I'm keep my eyes on it too see if it happens again.
Thank you anyway. have a good day 🙂
08-07-2022 07:07 AM
Thanks for the update. It is kind of weird! Have a good day as well!
Game on!
10-05-2022 04:02 AM
i have the same issue and does not fix like kylekaturn, still persist.
same escenario:
While I'm using virtual desktop (using PC as normal, I mean working on windows, not gaming) everything works well, but when I move my mouse cursor over any type of text field, mouse cursor become invisible immediately (white colour really).
Cursor become visible again (black colour or normal) as I move cursor out of text field.
happens with all text in all its meanings: Mails, webs, office... whatever have text and not being a link
In this moment while i am writing here mouse is white and i can not see it or select text normally, p.e. when i take the mouse out of editing field, mouse become black or flag and i can see it again.
I dont know if the issue is oculus or Virtual Desktop.
10-05-2022 10:32 AM
Hey there @ima.oiar! We'd love to look into this further with you to see if we can improve this experience with you. Please gather logs according to THESE instructions and then reach out to our email and chat teams HERE. This way, we can ensure that AirLink is running properly on your PC and see if there's anything else that's causing this. Thanks!
12-13-2023 01:13 AM
same here. Mouse pointer disapears and is shown again when i wiggle the controler
Oculus-appversie 60.0.0.162.352 (60.0.0.162.352)
12-13-2023 01:43 AM
I'm actually having the same issue. Would you mind posting the solution in this forum, so the thousands of people who don't login can see what has to be done?
Thanks for the help in advance!
12-13-2023 06:10 AM
@Emvyell i removed the beta oculus app and are now on the standard release. problem is solved
