12-04-2021 10:02 AM
after many months I still can't get my oculus rift s running. I did all the support steps that you recommend, until I returned the previous updates. but nothing works.
someone who can help me.
case
Stop Oculus service (Debug Tool -> Service -> Stop Oculus Service; sc stop "OVRService" may work too)
Back-up and remove everything in the C:\Program Files\Oculus\Support folder except the oculus-dreamdeck-nux, oculus-touch-tutorial, and oculus-worlds folders
Copy archive contents into that folder of whatever version you're installing
Do steps in README.txt in Prevent Oculus Client Updates.zip to prevent Oculus from automatically updating itself
Start Oculus Service (step 1 with Start instead; also sc start "OVRService")
Win
Rift users may need to run C:\Program Files\Oculus\Support\oculus-drivers\oculus-driver.exe.
12-04-2021 01:45 PM
Try this:
I had the same problem, not used my Rift S for 2 weeks and now constantly disconnecting > Firmware update > missing display port > and this again and again. (nothing chanched at my PC, but maybe a windows update)
Now i found a way it works:
-You need "MSI Util V3" (ask google)
-disconnect Rift S
-in Oculus App also remove the headset
-open MSI Util (as admin) and deselect/unmark "MSI" on your USB Controller, then press APPLY on up/right and restart PC.
-open Oculus app and connect your headset normally
....mine is now working again without disconnect.
12-12-2021 06:29 PM
ok!! I am going to try
