02-18-2022 07:15 AM
so ive been tryna turn off the graphical layers i think its named in the rift settings menu but it wont turn off every time i press it to turn it off it will do the animation if it turning off but will turn on again by itself
02-20-2022 08:42 AM
Hi tom6nicole! That is not what we like to hear! We would like for you to try these couple of options:
If power cycling doesn't work:
We do hope you find this information helpful!
08-17-2022 12:45 PM
Hey I have the same issue. Have you fixed? And if yes, could you help me how did you do that?
