i need help my oculus quest 2 wont recagnize my pc when strying to use airlink
bo.lindsey.750
BlueberrieSmoothie
Meta Quest Support
Meta Quest Support
Hey hey! Connecting to your PC is definitely a great way to take VR to the next level, and I'm happy to do what I can to help you out. 😁
First things first, you should check to make sure your PC is compatible with Link/Air Link
If everything is compatible and meets those requirements, the other thing I would suggest checking first is that all of your drivers are up to date.
If you're still not able to connect, let me know! We can see what other troubleshooting steps we can try. (And if you're getting any error messages, please send a screenshot of that as well.)
