might sound crazy but i want to try it so bad but i want a tech opinion in this ^^
xXT4M3RXx
i am thinking about doing something cuz you know wired connection with always better than any wifi i already ordered the kojak design cable the one with the smart charging chip to be able to extended my playing time that will charge the headset to 80% then stop until it drops to about 70-74% then charge again etc, but what i am thinking about is what if i bought a usb thunderbolt mini hub that has a usb c slot and also a usb3 plus rj45 slot and i connect everything to it and put it in the headset or in my pc would it work you know that way the speed would be 10gbps on the rj cable faster than the official oculus quest cable i am not a technician so i am not sure if its going to work or not but just the sound of makes me super exited to try it out
xXT4M3RXx
as you can see here on this pic this model is able to provide power through the hub so that means it will be charging up while connected
