07-15-2022 02:37 PM
hello, good morning, guys, one question, I bought the oculus and I want to see my pc there, but I don't know how to do it, what do you recommend doing because my pc doesn't have the air link requirements and the cable I have is very short, how do you record?
and when I connect it by airlink it connects but in the oculus it charges and it never finishes charging the 3 points and by cable it says that my pc is not very compatible and I don't want to change my pc because I bought the oculus 2 days ago
07-15-2022 03:29 PM
If your PC is not compatible, all you can really do is change whatever part is needed to make it compatible. What sort of graphics card do you have? That's normally the sticking point.
