quest 2 airlink declines to the right side
octaa.belacin
A weird thing is happening to my quest, when I use it stand alone its ok, but since a couple days when I use it on airlink only the right side of the screen looks like declined when I turn arround to the left, Its really weird and its at the moment I start airlink, never happened before
BFogh
I have the same problem it skews my picture on the rights side, so Airlink is not really usable anymore
Hello! We see you're having some problems with the airlink, which is not fun. We understand your concerns, but don't worry, Meta is here. Let's see what we can do to help you resolve this issue.
Could you please try the following:
  • Reboot the device.
  • Check the strength of your WiFi.
  • Restart the computer.
  • Check that your computer is up to date.
  • You can also experiment with the Oculus link cable.
Those steps should help with your problem. If you are still having problems after following those steps, please open a support ticket here and an expert will gladly assist you.
