10-30-2021 06:51 PM
Has anyone else been having this problem?Everytime I try to record gameplay videos on the Oculus Quest 2,using ADB commands via SideQuest,so I can record in either 4K or 1080p with a widescreen or 16:9 aspect ratio...the recording would abruptly stop after a few minutes...and the saved file can't be accessed....I've noticed it seems to consistently cutoff just alittle under the 4 gigabyte mark when recording....any help would be greatly appreciated....
10-05-2022 06:09 PM
Yes, having problems similar to your post over the last few weeks. Did you find the answer?
