Rift S and Rift 1.39 PTC Release Notes
Oculus Community Manager
Dash
  • From the Dash Settings panel, you can now set your Passthrough session length to “unlimited,” which will make Passthrough visible while using Dash.
  • Guardian setup will now attempt to automatically detect the floor height for you. You can still manually adjust the height if needed.
  • When using the virtual desktop feature in Dash, the virtual keyboard will now automatically open when you select a text field.
Oculus Home
  • Your Home UI now includes a history of the Homes you’ve visited, in the Places UI section. Homes you’ve visited in the last 30 days can be visited again with a quick button press. You can clear out your history or opt out entirely in the Settings UI.
  • Never miss a Home reward pack again! Updated notifications now let you know when you have a reward ready to open. Also, notifications in Home have been redesigned to make things easier to read and understand.
  • Now you can use Home gateways to load directly into your favorite app. In addition to setting up destination gateways to your own home and your friends' homes, you can now set up an app as a destination and use it as a simple and quick way to get into your favorite experiences.
  • Home now features a camera, accessible straight from the Home Menu. Look on the bottom for the camera icon, and open the camera to capture your favorite moments in your Homes or Homes you're visiting. Take selfies, or screenshots, and find these images in your Documents/OculusHome/Camera folder.
Fixes
  • Fixed an issue where Dash could crash if you had non-Unicode characters in your username.
Note:
Update 7/11/19 - This issue has been resolved with the latest PTC update (1.39.0.268010).
There is currently a known issue with 1.39 PTC that prevents it from working properly on Windows 7/8. If you are on Windows 7/8, please do not opt into the PTC at this time. If you already received the PTC update and are experiencing issues on Windows 7/8, please use the Oculus installer and perform a repair install to go back to the 1.38 release.
165 REPLIES 165
Orkel
Does this include static flash fixes or controller tracking fixes (randomly stuck in midair)?
Edit: Static flashes are still there, just got one. But the close-up camera tracking of controllers is vastly improved, I can rub the front of the headset with the tracking ring and it's still tracking perfectly. I'm not sure how you did it, but I am pretty sure this update includes those tracking improvements people have asked.
mhajii210
No static flash fixes??? That's a real bummer ☹️
Orkel
I guess the flash fixe comes as a firmware update later. Just the fact we can finally play FPS games without having the controllers glitch out near the headset makes this one of the better S updates so far imo.
kavange
There are obviously tracking improvements in this update but it isnt even mentioned in the notes. Very strange.
profanicus
Are close-up tracking improvements also coming to Quest? 🙂
Krueschel
While trying to calibrate the Guardian Setup a "Fatal dash error" eccoured.
Cant finish the setup... great work
ivanbrazza
This update brought back the issues with OVRService not starting again. It was fixed with 1.38 but after opting into the 1.39 PTC release it's happening again. After just closing the installer I can start OVRServer_x64.exe manually and it all works fine. Anyone else?
pcfarrar
Yes same problem again, I copied the 1.37 version of OVRServiceLauncher.exe over the top of the new one and it's working for me now.
pcfarrar
Here's a link to the working OVRServiceLauncher.exe (1.38.1).
https://www.dropbox.com/s/zisxcernv3y5c3a/OVRServiceLauncher.zip?dl=0
When the update to 1.39 is installing at the end (final stage) you need to navigate to C:\Program Files\Oculus\Support\oculus-runtime
Copy the 1.38.1 OVRServiceLauncher.exe over the top of the new 1.39 one and then manually start the Oculus VR Runtime Service in Windows Services, the install will then complete and your back in business.
