07-09-2022 07:27 AM
I have just got a replacement headset but I’m stuck on the first screen that you see when you turn your vr on for the first time and can’t connect my new vr to oculus app
07-09-2022 07:51 AM
Hi! Thanks for reaching out to us! We'll be happy to help you get your headset set up. Can you make sure for us that you're using fresh batteries in your controllers? Can you try fresh batteries to see if your controllers connect? Let us know.
07-09-2022 07:54 AM
That did not work
07-09-2022 08:00 AM
Okay. We'd like you to turn off your headset by holding the power button for 30 seconds, then remove the batteries from the controllers and leave them out for at least 30 minutes. Then replace the batteries, turn on your headset and try setup again.
07-09-2022 08:04 AM
That is not working either it’s just telling me to pull something out of the bottom of the controller
07-09-2022 08:07 AM
Is the LED light on the controller ring lighting up at all?
07-09-2022 08:22 AM
It lights up light under the ring
07-09-2022 08:29 AM
Okay, that's great to hear. We'd like you to factory reset the headset by following THESE instructions under "To perform a factory reset using the headset." Let us know how that goes for you.
07-09-2022 08:50 AM
That didn’t work it’s still telling me to pull something out the bottom of the controller
07-09-2022 08:59 AM
Okay, thanks for trying that. We'd love to help you further on this so please submit a support ticket HERE, and we'll get this figured out. Thanks!
