It would depend on the model. The top end macbook pros have amd radeon mobile gpus. I don't know if the mobile radeons are supported by Link, but the desktop ones generally are. So there's a chance.
The other macbook pros are intel gpus only. They won't work with Link.
Also you need to be running windows, OSX isn't supported.
